Get all text from front panel programmatically
Hey guys. I am looking for a way to programmatically get all of the visible text from the front panel of a vi. Currently I'm getting all control references and for each control getting the type and using property nodes to extract the text that is visible depending on which control type it is. It works fine, but I'm wondering if anyone has a tool out there that does this or can think of a more efficient way of doing it?
(4,276 Views)
Would this work for you?
(There is also a method to do it programmatically)
(4,269 Views)
These methods will return you all the strings in the VI except the values in the controls (labels, captions, list items, etc). If you want absolutely all the strings, you'd need to combine the method above with the one danijobe is already doing.
(4,253 Views)
OpenG has a function in the Variant Config File menu called Write Panel to INI. This works for writing control values to a file.
MGI has a function called Save Front Panel Data that does basically the same thing.
aputman
(4,240 Views)
