Get all control/indicator objects of a VI with C# (.NET)
Does know anybody a possibility to get all the "control/indicator" object of a VI with C#?.
I know how to do it inside LabVIEW (get the panel property of the VI  and from there I can get the Controls[] property)., but I can't find it in the LabVIEW COM component. Smiley Sad
Regards
Risotto
(3,609 Views)
hello risotto,
the VI server properties should be also accessible via ActiveX, see the following links:
Functionality Provided by LabVIEW as an ActiveX Server
Enabling LabVIEW as an ActiveX Server
kind regards,
robert h
NI germany
(3,591 Views)
Hello Robert,
Thank you for you answer, but I already know this help in LabVIEW. The point is that you can access to the panel property from a VI instance in LabVIEW (with the property node), but the same property is not existing in the ActiveX.
Risotto
(3,548 Views)
hello risotto,
there are not all VI server properties and methods exported in ActiveX.
so you can access elements on the frontpanel only, if you know the name.
kind regards,
robert
(3,536 Views)
Yes, that's exactly my problem.
So if I god understand, there is no solution to my problem now.
Risotto
(3,534 Views)
hello risotto,
as far as i know unfortunately no,
regards,
robert
(3,528 Views)
