Get a pointer to a VI
I am using an ActiveX control that wants me to provide a pointer to the location of a sub routine.  The subroutine processes information passed back by the ActiveX control. How would this be coded in LV?  In C++, it looks like the code below:
int ProcessFile(const char *filein)
SetOutputHandler(myOutputHandler);
// addtional calls to ActiveX to process filein
void myOutputHandler(int type,int param)
  // routine to process tyep and param
So to sum it up, how do I create  myOutputHandler in LV and provide the ActiveX control a pointer to it?
(3,228 Views)
Only way to get a pointer to a vi is to build the vi into a dll, and use
loadlibrary and getprocaddress to get a pointer to the function.
There is actually another way, that uses .NET to get a pointer to a callback
that is inserted into a com object or something like that. I don't have any
experiance with that though.
Wiebe.
(3,191 Views)
Hi there
if the control exports an event then you can use the "register event callback" function. This will let you pass a VI reference to a vi that will be called when the event arrives.
Can you post some code (including the control)?
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,182 Views)
No.... unfortunatly no event is returned by the .dll.   It insists that I pass it a pointer and the it will decide when my code will be called.  I tossed that particular software in the trash and am going with a software vendor that is a bit more complient in the ways of coding.
I looked at the .net stuff as well as it might have worked with the whole delegate and proxy, but again decided it was too much trouble.
Thanks for the feedback!
(3,150 Views)
