Get a list Box from two values Min and Max
Hi!
I have two controls Min and Max (int), I want to have the range of values between these 2 values in a list box.
For example : if  Min = 10 and Max = 20 , i want to have, as an indicator, a list box where there are all the values (int) between 10 and 20 (10,11,12...20).
Thank you in advance for your help.
(3,807 Views)
Hi
Looking for something like this?
Regards
J
(3,798 Views)
Hi samehA,
- create an array of your numbers
- convert that array to strings
- set those strings in your listbox using a "item names" property node
Which of these steps is a problem for you?
Edit: As you got a solution in the mean time I can suggest a variant too:
(3,797 Views)
Didn't think of the ramp.. this is why you're a Knight i guess! Smiley Wink
Cheers
J
(3,785 Views)
Hi J,
The ramp is just for fun, using the FOR loop as you did is my preferred way too.
But I'm a Knight because I would place the Add function after the loop - it's polymorphic… 😄
(3,780 Views)
