Get XControl label name from within XControl
Hi all,
Is it possible to get at  the label name of an XControl placed on a front panel from inside the XControl?
I want to set some labels in the XControl facade to the name that the XControl is given on a front panel.
(3,608 Views)
Hey Toad,
I'm a little unsure of what you're trying to do. Getting at the label of the XControl in LabVIEW is easy enough, it's just a property node.
Are you saying that you want the XControl labels on the facade to take the name of the XControl?
Chris
National Instruments - Tech Support
(3,586 Views)
Hi Chris,
Thanks for the reply.
I'm trying to get at the name the XControl is given when it is placed on a front panel vi.
I'm not sure what this term is called: the variable name? the instance name?
I'm hoping to access that value from inside the XControl so that a label inside the XControl will display in its facade what the variable/instance name for the XControl is on the front panel.
Phill
(3,584 Views)
Accepted by topic author tadders
So you want a self-aware XControl?
This will do it.  Take the refnum in your "Container State" and do the following
Shane.
(3,576 Views)
Hi Intaris,
Perfect!
Thank you very much.
P
(3,565 Views)
