Get PString_ogtk.vi
When I am trying to run of the programs I get the following file missing.
What is this exactly and how do I get it. Am I missing some pacakge ?
Thank you 🙂
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(3,959 Views)
Yes, OpenG (free at http://wiki.openg.org/Main_Page, except that it seems to have been defaced at the time I posting this link).
Free to download, install and modify. Highly recommended add-on.
(3,957 Views)
Accepted by topic author abikutn
Try this direct link to download JKI package manager (free for non commercial use), which will give you easy access to all packages released under the Open G license.
(3,956 Views)
I installed all openG packages using VI package manager  ( from the link you privided ) . But as long as the VIPM stays the openG stays in LV. If I close the VIPM then I dont see openG tools in my function palette anymore.
Is this how it is supposed to work ? ...
Thanks ...
Abhi
Abhilash S Nair
LabView Gear:
(3,934 Views)
Have you tried closing and restarting LV?
Ben64
(3,927 Views)
Yes . Even restarted the computer. But I dont see it.
Let me try again .
Abhilash S Nair
LabView Gear:
(3,924 Views)
I had LV 64 bit and 32 bit installed. I had installed on 64 bit so it dint reflect on 32 bit LV. that was the problem
Thank you 🙂
Abhilash S Nair
LabView Gear:
(3,922 Views)
