Get Latest Version from Source Control
I have a large number of vi's checked into Source Code Control. What I'm trying to do now is bring all the files down, from Source code control, to another computer that has none of these vi's, yet, as local. The only way I can see to do this is to get on the new computer, launch the SCC provider, select my project, then select Changed Files from the Selections menu, then select Get Latest Version from the File menu. This approach appears to be working as, slowly but surely, my file structure is building up on the new computer. The problem is that I constantly have to keep hitting cancel, when it can't find a subvi of a vi its trying to bring down. Is there a fast way to bring down the files stored in SCC onto a new computer that do
es not yet have any of those files stored as local?
(2,714 Views)
For example, let's say all your VIs are stored in C:\Dir1\Dir2\ and your master directory is C:\Master\.
You should make sure this remains unchanged in your new system. I usually backup on 2 systems and I did this. Works fine. Let me know if this helps.
(2,714 Views)
