Get Image from XY Graph
Dear sir
I'm plotting the Polar and Rectangular plots simultaneously.
Please find the enclosed VI.
From front panel if I select plot type as rectangular it is saving the both plots with data, but if I select plot type as polar the data in rectangular plot is not saving.
I have customized the polar plot, after opening the VI if it shows any errors please replace the polar plot.
Kindly resolve the issue.
S Nagaraju
Message 1 of 11
(6,303 Views)
Hi Sonti,
I surprised that when rectangular is visible and polar is hidden it saves both images. If I make a simple VI where I set visible = False for both plots, then all I get is a grey rectangle as the image. But, I verified the behavior you are talking about.
I think your best bet is to make sure whatever plot you want in image of has visibility set to True before taking the image data.
Message 2 of 11
(6,255 Views)
Hello gregoryj,
Plot type is only for visibility.
Irrespective of selection both plots to be saved with data. But when i select plot type as polar the data in rectangular graph is not saving.
Please find the enclosed images for more clarity.
S Nagaraju
Message 3 of 11
(6,245 Views)
Yes, I understand the issue. I just think something is not being updated sometimes when the XY Graph is hidden, so I would make sure whatever graph you want an image of has Visibility set to True before you get the image data.
Message 4 of 11
(6,225 Views)
Hello gregoryj,
Ok I'll make visibility true before saving.
Can you please explain the issue, why data is not saving when rectangular graph is hidden.
S Nagaraju.
Message 5 of 11
(6,214 Views)
Probably NI doesn't bother updating the appearance of that graph when it is hidden because why waste the time to do that when it isn't displayed.
Message 6 of 11
(6,208 Views)
Then why polar plot is saving when it is hidden??
S Nagaraju
Message 7 of 11
(6,202 Views)
Different control type.  NI handled the updating of its appearance differently.
Message 8 of 11
(6,193 Views)
Thank you very much the replay.
I have one more doubt, actually in rectangular plot the X-axis coordinates are -180 to 180. After plotting a horizontal line which is joining from 180 to -180. How to remove the joining line.
Please find the enclosed pic for more clarity.
S Nagaraju
Message 9 of 11
(6,177 Views)
Accepted by topic author Sonti_11532
"reply".
Do you mean you have a question?  "Doubt" means you don't believe something to be true.
To get rid of the horizontal line, you basically need to put a break in the data.  If you arranged your data so the array was truly -180 to 180 then you'd be done.  I'm guessing your data starts and ends elsewhere and it makes a jump from 180 back to -180 somewhere in the middle.  What you can do is insert a data point at that discontinuity that has a value of NaN for the X, Y, or both.  NaN values do not print on a graph or chart in LabVIEW.
Message 10 of 11
(6,157 Views)
