01-10-2019 09:56 AM - edited 01-10-2019 09:58 AM
"URL Get HTTP Document.vi" seems not to work if used with a https URL. I get an error 18000 (Internet Toolkit: Invalid URL protocol). Is it just me (I'm a bit outdated, using LV 2011) or is it actually a limit of the function? Are there alternatives for https protocol?
Solved! Go to Solution.
01-10-2019 11:28 AM - edited 01-10-2019 11:28 AM
You should not use the function from the Internet Toolkit. This indeed does not support HTTPS, as it is written fully in LabVIEW and that does not allow SSL sockets.
You should instead use the HTTP Client VIs in the TCP Palette. These functions call an external library that uses internally curl and that does support HTTPS.
01-11-2019 02:46 AM
The GET function in the HTTP palette works fine without anything else. Thank you
