Get Description "location" from Property Node VISA Serial Port
I'm using the SilLabs 2102 https://www.silabs.com/Support%20Documents/TechnicalDocs/cp2102.pdf .
There are 3 of these on the test fixture and occasional after a reboot or changing the testhead the com ports don't come up in the correct order
I have programmed the eeprom on each 2102 uniquely with certain strings that show up in the "location" if you go to device manager/ com ports/ properties.
I need to write a VI that will read the "Location" string from device properties and compare it against the com port it came up as.
Problem is I can't seem to find the right property node that has this information?
Any help would be greatly appreciated.
-D
(2,665 Views)
You need to utilize the DAQmx task property node and select devices under the drop down menu. To get this property node you can go to measurement I/O/NI-DAQmx/Advanced / I/O Constants / DAQmx Task Property Node.
Basil
Applications Engineering
(2,624 Views)
