Get Control label in SubVI
Greetz All,
Is it possible to get the label of a control that is connected to a subvi from within the subvi without creating a control reference and connecting it to the subvi?
I'm trying to make some new general use subVIs, so I don't want to get a reference to the calling VI and get refs to all its controls and search for the label because what it would search for will change from application to application, so I would have a string input for the label to search for anyway.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(4,213 Views)
Hi Ed,
I think this would be great, but I doubt it's possible. It's the wires which are connected to the sub-vi connectors, not the controls directly so the assumption that wire=control is often false, and I don't think LV will offer this ability. If I wire a control "number" to a "+1" function and send this to the sub-vi, what should be given as the connected "control"?
Having read your question however, I've been thinking of other ways which may produce the same functionality. Apart from a standardised naming scheme, I can't think of any right now.
I just know this will keep me thinking for a while.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,213 Views)
I realized the "wire=control" issue late yesterday. And even though I figured out how to get the control name using a variant input ternimal, then use either 'Get Variant Attribute' or convert to XML and parse out the label, there's a good chance the label will not be there anymore for one reason or another, or that there never was one because the wire didn't come from a control.
So I've reverted back to just using a serarate string input to get the needed string into the subVI.
Ed
(4,213 Views)
Hello!
I also want to get label of control connected to my subVI. I have a variant input to the subVI and  I'm was trying use "Get Variant Attribute" but what next?
Sakubh
CLAD
(3,735 Views)
I just want label on output my subVI from any kind of connected control. Input is a variant.
CLAD
(3,709 Views)
I found the solution. I just use OpenG function "Get Data name".
CLAD
(3,696 Views)
The OP mentioned in the first post the fact that he wanted to get the control name, from within a subVI, of the calling VI.  In this instance the OpenG funtion won't work.
(3,688 Views)
