Generic error when loading vi. Error code 37.
The program was developed using the LabVIEW 8.5 professional version. I tried to load the same program using the 8.5 labview base version. I received generic error "Error Code 37.
(3,503 Views)
Hi brian5,
at which place do the error occur? Can you give more infromation about it?
Trying to help.
Mike
(3,491 Views)
Error 37 is a "Device not found" error. I would expect to see this if you ran the code and you were trying to use an interface that doesn't exist on that computer, such as a COM port. However, you said it happens when you load. The Base development version does not contain all the libraries that are provided with the Professional version. Were you by any chance using a function that only exists in the Professional version?
(3,477 Views)
