Generic USB control question
Does anyone know if this information would apply to talking to any USB device?  I am assuming I would need to use the RAW format to talk to a device that does not meet the instrument USB communication standard.
1.  I want to plug a usb based microcontroller dev board into my pc
2.  Load the drivers that windows requests
3.  Use a utility to acquire whatever i.d. information I need from the microcontrollers USB i.d.
4.  Then use labview to simple send a text string or numeric string from the PC to the microcontroller.
Best Regards
Tim C.
1:30 Seconds ARRRGHHH!!!! I want my popcorn NOW! Isn't there anything faster than a microwave!
(2,617 Views)
Hey Tim C.
The forum that you linked will indeed allow you to use VISA commands to control a USB device. The inf file created will associate your micro-controller and NI-VISA together. From this, you can use LabVIEW to send commands that the controller will recognize to obtain information about it. I would recommend using one of the VISA example programs, such as the USB RAW - Control.vi
Hope this helps
Can Wong
(2,584 Views)
