Generic File I/O Error when running Startup application
I get a 'Generic File I/O Error' when I try to run a RT startup application. I can run the VI from Labview without any problem, but when I deploy the code as a startup application, I get the error before the VI is opened.
The error is shown at the embedded UI of my CRIO. I can click 'OK' and after that the VI will be opened and the code runs without any problem.
The file which causes the problem is not mentioned.
I use Linux RT (2024 Q1) on a cRIO-9040.
Has anyone an idea?
(1,070 Views)
Maybe it is related to LabVIEW Generic File I/O Error: The File 'lvuser' Could Not Be Loaded?
https://tmesystems.net/
(1,037 Views)
Thanks for the answer, but it don't solve the problem. I tested with two versions (with and without non-ascii characters). The error occurs with both.
Also there is no file mentioned, which causes the problem. Is there a possibility to find out?
(994 Views)
