Generator -- > analyzer
I have created a waveform which consists of a number of pulses! I want this waveform to be sent (by an SMA cable) from the generator (PXI 5610) to the analyzer (PXI 5600)!
What blocks should I use in each device in the labview environment?
Thank you
(2,782 Views)
There is more information need to answer your question, like is it a digital waveform or an analog waveform. A better approach might be taking a look at our examples “C:\Program Files\National Instruments\LabVIEW 8.5\examples\instr\niRFSG” and check which one of those will suit your needs the best.
When you ask for “block” my guess is that you refer to which functions you should be using, right? If that is the case RFSG and RFSA have their own drivers that you probably already have installed. And the function you will need to accomplish this will be there.
If you take a look at the example: “RFSG Arbitrary Waveform Generation.vi” you will see how the sine wave is generated inside the “case structure” and then pass to the “niRFSG Write Arb Waveform”.
Let me know if it helps
Jaime Hoffiz
Product Expert
(2,750 Views)
It is an analog waveform. I have created it with the 'formula waveform' block giving the mathematical expression (function) of the pulses!
I have used the examples that you said to me and and I' ve managed to transmit the signal from the generator to the analyzer! I must now measure the distance between the pulses!
I let you know if I have any other problems!
Thank you very much for your valuable help!!!
(2,733 Views)
