Generation of controlled pulse duration using NI-USB 6008 DAQ
hi
in continuation of my previous thread  "can i use NI-USB 6008 DAQ for generating pulse" i need some help about generating a controlled pulse duration on one of the digital output lines of DAQ, in my idea i want to use function generator vi to produce a square wave with in while loop and then the high and low pulse duration can be controlled interms of setting up high and low pulse time in second just like a timer switch.
the user can set up the time so that  pulse could be generated with varing dutycycle.
my question is how do i set the time for both On and Off conditions in other words?
may be the attached  image help u understanding my question
thanks
(2,994 Views)
You will find an example of PWM for 6008 here: http://forums.ni.com/ni/board/message?board.id=70&message.id=5527&requireLogin=False
(2,987 Views)
