Generating interrupts using 7831-R RIO and LabVIEW FPGA
I have written a FPGA vi that runs on the 7831-R RIO Card. This generates an interuupt when an operation is complete, so that the host can process the data. This works well when using a Pentium 4 PC. The host LabVIEW program receives the interrupt and is able to acknowledge it. However, this does not work when transferring the host program to a Pentium 2 machine. It waits for an interrupt indefinitely and I have verified that the FPGA module does complete the operations preceding the genration of an interrupt.
Are there any other settings that need to be taken care of so that the host program is able to detect the interrupt?
Thanks.
(3,153 Views)
If you have all the necessary software drivers installed, there should not be any specific settings that are reuqired to enable interrupts. Have you verified that you have the same version of SW installed on both systems?
LabVIEW FPGA module
VISA
NI-RIO
Do you have any other cards installed on your Pentium 2 system that could be causing an interrupt conflict with the RIO card?
Christian L
NI Consulting Services
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,153 Views)
