Generating and Acquiring Analog Output with cRIO in Scan Mode
I have been attempting to perform what I thought would be a relatively simple task using a cRIO 9048, an NI 9269, and NI 9239. The 9269 is just to generate a basic signal and 9239 to read in said signal. I've configured both modules to run in Real-Time Scan [IO Variables] mode. The VI is pretty self-explanatory so I will just provide the screenshot.
The true case in the first loop simply provides a 5, rather than 0, to the AO module. This runs fine but I read nothing on either end. Nothing comes out of AO or into AI. Nothing appears to change in the distributed system manager. I'm unsure as to what I could be doing wrong.
Message 1 of 1
(2,310 Views)
