Generating an executable with LabVIEW 6.0.2 with serial comm.
I'm generating an executable with LabVIEW 6.0.2 that uses serial port and the paralell port. Do I need to include any special file (like serialdrv LV5.0)?
(3,141 Views)
"serpdrv" is the file that you need to include in the same location as your executable. It is found in the same location that LabVIEW is installed.
-Jim
(3,141 Views)
If you are using VISA to control the ports then you need to install VISA RTE on the traget machine.
Brian
(3,141 Views)
First at all, thanks for your comment.
But what I have to do to install the VISA RTE on the target machine ? Do I have to add it as a support file when creating the executable ? Where is located that drive (VISA RTE)?
Thanks for your time !!!!
(3,141 Views)
