06-11-2007 03:50 AM
06-11-2007
04:36 AM
- last edited on
08-19-2025
12:27 PM
by
Content Cleaner
PXI 4472 is a DSA card and has8 Analog Input channels and no Analog output channels
PXI 6602 is a Counter timer card with 8 Up/Down counters and even this card has no Analog output channels.
So, you will need to get a new DAQ card that has AO capabilities
This link will help you choose a suitable AO DAQ card
06-11-2007 05:24 AM
06-11-2007
06:18 AM
- last edited on
08-19-2025
12:27 PM
by
Content Cleaner
PXI 6602 has DIO lines ( each can be configured os DI or DO)
It has 32 digital I/O lines (5 V TTL/CMOS) of which 8 are dedicated and 24 are shared with counter/timers
For getting started, You can use DAQ assistant or Example vi's shipped with LabVIEW
Find Examples>>Hardware Input Output>>DAQmx>> Digital generation Folder, shall have the relevant vi's
Any further doubts, do ask
Dev
06-13-2007 12:39 AM
Thanks Dev once again,
I have tried to run one of the shipped vi examples (write Dig Chan.vi), but because of my basic knowledge, I still couldn't get a digital output signal. I configured the 32 lines of the PXI 6602 as DO using the DAQmx Assistance, and have a cable connected from the PXI 8196 (RT) to a CB-68 LPR terminal which has 68 terminals, but I don't know which of these terminals are my outputs and which is the GND terminal.
Also, if I want write my own program, how to download the vi from the PC host to the RT so it can ran independently.
I appreciate your patience with me.
Mike
June, 13
06-13-2007
04:10 AM
- last edited on
08-19-2025
12:28 PM
by
Content Cleaner
