Generating a Code39
this is the latest
Message 11 of 16
(1,387 Views)
01155990@pw.edu.pl wrote:
this is the latest
Did you mean to attach something?
Message 12 of 16
(1,369 Views)
Thanks for sharing for LV 2020. I noticed that the values generated never changed no matter the input.
I changed the routing of the cluster to bundle AFTER the case structure.
Before the change, the case structure had no effect on the result, showing always the same result.
It changes now, but the height needs some adjustment.
Good luck !
Message 13 of 16
(1,350 Views)
Thank you very much for your help. May I ask if you can upload the file here so I can have a better view at it and understand it fully. Thank you again
Message 14 of 16
(1,328 Views)
I just rerouted the input of the cluster, the unbundle receives AFTER the case.
Message 15 of 16
(1,314 Views)
You remind me of one of my former cow-orkers.  He's a hack.  He puts practically no thought into anything.  And of course, like you, he puts zero effort into producing clean code.
I threw most of your mess away and came up with this.
Message 16 of 16
(1,307 Views)
