Generate two tone with freq. sweep
HI all,
My code is generating one tone with frequency sweep. I am trying to generate another tone and make one as a fundamental tone and another one do frequency sweep.
I've injected one of the NI examples which uses arbitary spacing or uniform spacing in my code but both of them uses without sweep. please can I find anyone can help me to know how to do it? by the way I couldn't attach the hole subvi to the main code becasue the sizae is too big.Thanks in advance
Regards
Message 1 of 9
(4,285 Views)
up
Message 2 of 9
(4,109 Views)
I am trying to generate two tone, one tone is constant and another tone has frequency sweep. one of the colleagues advice me to configure f1,f2 , generate and abort, and configure f1,f3, generate and son on as mentioned in the attached photo. but message pop in tells me there is something wrong as per attached. Any advice?? thanks in advance
Message 3 of 9
(4,053 Views)
Please attach the actual VIs, rather than pictures of (part of) the Block Diagram.  With the full VI, we can look at the parts you didn't think to show us, we can consult the LabVIEW Help for functions we might not recognize, we can actually try the code and see what it does, and we can make sure we understand what version of LabVIEW you are using.
Message 4 of 9
(4,051 Views)
Hi Bob,
question answered by moving messages into older thread.
@Al:
Please don't create double posts on the same topic!
Message 5 of 9
(4,034 Views)
HI,
It's not the same topic, it's different question and you can check that!!!
Message 6 of 9
(4,018 Views)
Hi Al,
your first message:
from 2nd message:
This sounds the same for me!
Why don't you discuss this with your collegue?
Message 7 of 9
(4,015 Views)
HI,
as I mentioned before, same topic but different question. please try to read the whole message before you judge the people
Message 8 of 9
(4,013 Views)
Hi Al,
Advice: Read the error message.
It names the error location and the error reason.
Look for the location and solve the reason…
When it's the same topic: Don't create double post on the same topic!
When it's NOT the same topic: then why do you say so?
Message 9 of 9
(4,010 Views)
