Generate three different analog waveforms and two digital (.wav) sound files of your liking
i am new of working with signal at labview
i started to learn this new program 3 weeks again and having fun
for gereating analog siganl : i knew we going to use labview Signalexpress but when i tried to do i will be need to built in a channel or something to make the signal work. how can i do that?
also how can i use two digital (.wav) sound files of your liking?
can i do this all at labviewe program not in Signal express
thanks all and have great night
(2,793 Views)
can i use the sound as my channel and make the analog signal work?
(2,792 Views)
Hi never get own-
     One request regarding your first post: can you clarify your question?  I think you are asking about how to generate an analog output using a wav file, correct?
     Here is an example of how to generate a sound output from a wav file.  In addition, there is the Acquire Sound Express VI, found on the block diagram under Express»Input.  This might assist you if you are wanting to acquire a sound input from a device.
     I hope this helps.  Best of luck with your application!
Gary Parente
National Isntruments
Gary P.
(2,762 Views)
