Generate sinusoidal waveform using feedback loop control based on NI FlexRIO (NI 7972 FPGA target, NI 5783 adapter)
Hello
I'm working on a project based on the example getting started 5783 like you.
My problem is that when I compile by referring to the bitfile, the project works perfectly, but when I refer to the VI without changing anything, I have an error in the stream on the AO loop.
I tried to do some modifications in the FPGA VI and compile to have a new bitfile, the project don't work by refering the new bitfile.
It only works by referring the bitfile by default !
what can be the problem !
thanks
Message 11 of 12
(678 Views)
