Generate graph from output of the formula of time varying input
No, a chart would be the wrong tool. A chart maintains an internal FIFO buffer of a given size and discards old points as new points arrive. It acts like a paper chart recorder.
You definitely need a graph, because you have all data available at once.
Make sure you fully understand the difference between a chart and a graph, they are completely different.
@pyae wrote:
I think current output is  already quite ok for me but i am wondering generating with waveform chart would be clearer to see and compare with others .
What do you want it to compare with? Other days?
You could use a multiplot graph with one plot per day, for example.
Message 11 of 14
(1,145 Views)
Hello Altenbach,
Thanks for your advice and i will use the graph .
I would like to compare data with other day but not compulsary  and i have to integrate this data with Solar data and Cost calculation part as well which is being done by our other project member.
Really thanks alot for your help and i will update you for other part of project if necessary.
thanks
regards
sweyiwin
Message 12 of 14
(1,135 Views)
Hello Altenbach,
Please advise me which tools shall i use to extract every 30 mins data from power array and put them into one array. So i will have new array with every 30 mins data (eg. data from index 0, 30, 60, 90, ... ).  please find my attached project part.
thanks
regards
pyae
Message 13 of 14
(1,113 Views)
Hello atenbach,
i could have done the above array extraction part already.
thanks
Message 14 of 14
(1,097 Views)
