Generate analog values using 6052E and wait for a specific time between each generation:
Hi Dennis:
If I have to set a certain amplitude for the sine wave, and then run it at different frequencies which of the two should I use.
Sine Pattern. vi
or
Sine wave. vi
I have a DC offset and a certain amplitude for the AC part.  I have to change the frequency of the AC part at that amplitude from 10-1000 Hz.
Mizar.
Message 11 of 19
(1,320 Views)
Sine Wave is probably a bit easier to use.
Message 12 of 19
(1,312 Views)
Hi Dennis:
I have this setup based on the previous VI.  However, the output only shows the DC offset.  I cannot see the AC component?
Mizar
Message 13 of 19
(1,309 Views)
Hi Dennis:
Had one more question for you.  As you know, I have PCI6052E with SCB68 running LabView 6.1.  I can generate a square wave, but I need to change the width of the pulse.  Which way do you think I should go?
Mizar.
Message 14 of 19
(1,305 Views)
The f input is not in hz. You can read the on-line help for an explanation. I don't have time right now to do an example. I was searching though the shipping examples and ound one that uses uses Sine Pattern. Open the shipping example called Basic Single Tone Measurements. There is a subVI in there called Create Test Signal. Look how the frequency is set. Do you have the Analyze>Waveform Genration palette. There is a function there called Sine Waveform. You can use this or look at the block diagram to see how the f input is correctly calculated based on sample rate and desired frequency.
Message 15 of 19
(1,296 Views)
Hi Dennis:
Is the example you had asked me to look at in Labview? I was unable to locate it.
Mizar,
Message 16 of 19
(1,275 Views)
The name in 6.1 is Basic Single Tone Detector Example and from the example finder browse tab is at Analyzing and Processing Signals>Tone Measurements. I had 7.1 open when I gave the name and I don't know if the name changed or if I just typed in wrong. The Sine Waveform function is on the Analyze>Wavefrom Generation palette as I mentioned and I believe it ships with all versions of LabVIEW.
Message 17 of 19
(1,269 Views)
Hi Dennis:
Thanks a lot for the tip.  I have successfully used the SINE WAVE GENERATOR to cycle different frequencies.  If I need to send a pulse with a variable pulse width how can I go about it?
Mizar
Message 18 of 19
(1,264 Views)
Look at the shipping example called Generate Single Pulse (DAQ-STC). Find Examples>Hardware Input and Output>Counters>DAQ-STC.
Message 19 of 19
(1,256 Views)
