Generate a '2 output instrument' directive to IVI driver
 I have a Tektronix AWG420 which I didn't find drivers for anywhere; however I did find an IVI driver for the AWG5x0 family in the NI drivers' zone.
As the command set for these instruments is almost identical I tried using it, and it works great with my applications for Channel1 if I turn of the 'ID query' at initialization.
However, as the driver doesn't recognize that I have a 2-output instrument I can't communicate with Channel2.
Does anyone know how can I give directives to the driver that this is a 2-output instrument?
Thank a lot,
   malosh
(3,245 Views)
Unless you want to buy LabWindows/CVI and modify the driver (orf ind someone to do it for you), I think your only option is to use tkawg5x0 Write Instrument Data to send the unsupported commands. This (and a read function) are on the Utility Functions>Instrument I/O palette.
Since doing this makes your program instrument specific and you lose most of the reasons for using IVI, you could always write a native LabVIEW driver or use the Instrument I/O Assistant instead of the IVI driver.
(3,242 Views)
