Generate Report Get Data to Modify.vi produces an error code 97
The "Generate Report Get Data to Modify.vi" produces error 97. I found some help regarding "font style.vi". The recommendation was to recompile the VI, but it didn´t work. Also to change the property node to a different property and back to the original didn´t work, too.
(3,245 Views)
You hit the big solutions. Have you been able to isolate where in the VI the problem occurs? You will probably have to dig in the subVIs. Also do you see this problem if you install on another computer? Consider also reinstalling LabVIEW and Office if you are using the toolkit.
(3,245 Views)
