Generate Random numbers
Hello All,
I have searched the forum and have realised, there are lot of random number generation ideas, however i have a different question, best explained by the attachment.
I want to have unique outputs.
your inputs are appreciated.
Message 1 of 13
(7,912 Views)
You need to compare the previous output with the new one; and skip it when the output is the same.
Message 2 of 13
(7,909 Views)
Instead of focussing on changing the output.. i would like to change the random input in such a way that it always picks a unique line.
My output in my program will be hundreds of line, and so i would not like to mess around.
Please let me know, if you need any more inputs
Message 3 of 13
(7,897 Views)
Yep better ways to do this
If I understand correctly (from your code) you want to shuffle the lines randomly See below
For improved randomness you ca generate a random seed to input to Riffle.vi
"Should be" isn't "Is" -Jay
Message 4 of 13
(7,886 Views)
Accepted by topic author Rambo333
I haven't seen your code because i'm using LV2009 but I think the attached vi will do want you want.
Ben64
Message 5 of 13
(7,881 Views)
I wanted to do something with the shift registers and converting my string to an array.... but my program was not very convenient to do so...
Thanks !!!
It works like a charm...
@ Jeff..
I will implement your style and see the results.
Thank you
Message 6 of 13
(7,869 Views)
I agree with Jeff that riffle is a cleaner solution:
Message 7 of 13
(7,863 Views)
Message 8 of 13
(7,856 Views)
If you only have LabVIEW base (no riffle!), you could do as follows (taking advantage that clusters are sorted in element order):
Message 9 of 13
(7,841 Views)
I'm thinking Randomize 1D Array will sufficeSmiley Very Happy  Thanks for point it out- (guess what just hit my reuse library?)
Message 10 of 13
(7,830 Views)
