Generate Pulse Train.vi
I am using the PCI6023E card and I want to generate a finite pulse train on one of the counters.  In my simple program, I only have the Generate Pulse Train.vi with the following input parameters.
Device number = 1
Counter number = 0
Number of Pulses = 20
Frequency = 20000 Hz
Duty Cycle = 0.5
What I observed on the oscilloscope on Counter 0 output is a continuous pulse train of 50% duty cycly at 20KHz.
Even the generate finite pulse train example in the examples library does not give me the correct number number of pulses.
How can I generate the 20 pulses with the Generate Pulse Train.vi?
Best Regards
hv
(3,016 Views)
Accepted by topic author voh720
OK I needed to connect the counter-1 out put to the gate of the counter...Solved.
(2,995 Views)
