Generate MAX Report for all systems found in NI MAX?
Hello all,
I'm still somewhat new to labview, and was wondering if there is a way to get a list of all the systems listed in NI MAX?
I am using the Generate MAX Report VI to create XML reports and am then parsing them to extract the info I care about, but currently have to do this one system at a time.
The VI takes an I/O variable as an input. Is it possible to somehow loop through all possible values for that? The default is localhost, but I also need reports for all the Remote Systems.
Any advice is greatly appreciated!
(2,713 Views)
Accepted by topic author rcrete901
Find Systems.vi can be used to get a list of all detected systems in NI MAX. You can take the array of hostnames that are generated by this VI and put use it to open Sys Config sessions to those targets in a for loop.
-Jordan
(2,683 Views)
Awesome! Thank you!
(2,678 Views)
