General strategies on producer/ consumer loop sampling, when consumer loop controls producer loop
Here is the code simplified some and turned into a pipeline.
Message 11 of 12
(661 Views)
What can I say crossrulz, the application has extremely demanding requirements!
The suggestion about using a pipeline architecture to take advantage of multiple processors certainly seems a good one at first glance. Focussing on performance only, when I tried to decouple the processing from the sampling in the producer/ consumer architecture it didn't improve matters, actually that was slightly worse, so I went back to my original single loop. I will try your suggestion next and see if that helps. Thanks.
Message 12 of 12
(641 Views)
