General problems with text sizing for Labview
I've attached some screenshots to demonstrate my issue. All text options on labview have their size too large. Most of the time this results in text being cut off halfway or being too large to fit in certain areas such as the functions palette regardless of my attempts to resize them to fit. I've tried adjusting my screen resolution but that didn't solve the problem. Any help appreciated thanks!
(3,667 Views)
Accepted by topic author jaffast
What is your OS version?
What is your font size setting in the OS? (set it to 100%, not e.g. 150%).
(3,636 Views)
So it was that I had set my text to 125%. That fixed it, only problem is that everythiing is tiny now. This may be a dumb question but is there a way to specifically change the text size for labview only?
(3,605 Views)
I think that if all your dev machines are set up the same way, you are okay.  The problem arises when the VI was developed on a machine with a different scaling.
Bill
CLD
(Mid-Level minion.)
(3,544 Views)
