Gates on XY Graph
All you have to do is save the data as the default value in an array then we can start working. It would be nice if it looked like what you expect your end product to look but we can adjust it after you get the ultrasonic sensor reading in LabVIEW.
Tim
GHSP
Message 11 of 33
(2,015 Views)
well, I want to build the program first in labview 2009 then export it to labvlew signal express where i acquire the data
Message 12 of 33
(2,014 Views)
I dounloaded the Ultrasonic A sacn vi's to see what you where doing. Can you use this program to do what you want? I am sure that it will need to be modified to meet you exact needs. So where do you need to start?
Tim
GHSP
Message 13 of 33
(2,008 Views)
I want my program to be the same as the above, just i will need to add some indicators in the front panel to show values of amplitude and time as well as gate positions controls,,,,the problem is that the above program is just for demo. purposes was issued by ni to show how Ultrasound can be implemnted in programs, so it does not work with the real date,this why i need to create my own
Message 14 of 33
(1,999 Views)
I recorded data for the sensor,,,see the attachment, hopefully it works
Message 15 of 33
(1,992 Views)
You can use the example that NI provided. You will have to add the data acquisition part so that you get the data into this vi. Do you know how to do that?
Tim
GHSP
Message 16 of 33
(1,970 Views)
That will be easier,
I do not know how to add the data acquisition part for the VI
also , can I add conrol to the gates
Thnx Tim
Message 17 of 33
(1,957 Views)
Any news?
Message 18 of 33
(1,931 Views)
It looks like you have control of the gate on the example. You need to change it and hit the configure button.
What data acquisition system are you using? How do you have the system wired to your computer? Give me more information and I will do what I can to help you get your signals to LabVIEW.
Tim
GHSP
Message 19 of 33
(1,926 Views)
I use ultrasonic pulser connected with Tektronix TDS 3054 oscilliscope which has BPIB to USB adaptor then to the computer,,,it works perfectly and I can acquire the data on signal express, the file that i attached to you yesterday was an example of recorded data
Message 20 of 33
(1,923 Views)
