GUI question making a cluster appear as if it's not grouped ??
I think this is a fairly simple question, but I'm having trouble doing this...
I've grouped several controls into a cluster...  When I run the front panel, I don't want all of those controls to appear recessed compared to the other stuff on the front panel.  how can I change it so the cluster is only obvious by looking at the block diagram?
thanks
-z
(2,854 Views)
Select the color tool and color the background of the cluster transparent (the T in the top right corner of the color picker).
To get rid of the frame, you need to right click it using the color tool and when the color picker is displayed press the space bar. This changes the color selection mode so that you can now color the frame transparent.
If this is too complicated to remember, you can also use the cluster from the classic controls palette, where you can easily color the frame transparent.
___________________
Try to take over the world!
(2,848 Views)
thanks...   I wonder why they make it so much harder for the modern controls... i would have never figured that one out on my own
-z
(2,829 Views)
