GPS navagation frame format in labview
I have a question in the GPS simulator toolkit. GPS simulator generates the GPS data based on selected the Ephemeris and Almanac files from the links provided in the Manual. The file niGPSWritewaveformtofile.vi would generate the GPS data into a external file (.bin file).  Can the simulator generate the navagation frames in RINEX format? Or, can LabView convert the file from bin to RINEX format?
Long
(3,342 Views)
Accepted by topic author Longgg
Hello Long,
The GPS Simulation Toolkit is designed to generate the over-the-air signal as seen by a GPS antenna. You cannot use it to process incoming GPS data or to generate post-processed GPS data.
It may be possible to convert GPS data to the RINEX format, but the GPS Toolkit does not contain any method for doing so. It would be necessary to perform the demodulation and decoding of the GPS signal yourself to accomplish this.
Dan King
(3,313 Views)
