Do you want to turn on your modem and establish a connection, all from your program?
If so, I think you may have a problem.
These things are usually controlled through DLLs, but to use a DLL with LV PDA, I believe you need to have the DLL's source code, so this won't help you.
You said you're using AT commands. What kind of interface are you using to send those commands to the modem?
Do you have the documentation which came with the modem, which will probably have a list of AT commands?
Have you looked in the manufacturer's site?
If this doesn't help, write in with more details about the PDA and modem models.
___________________
Try to take over the world!
