‎07-08-2002 02:38 PM
‎07-08-2002 02:55 PM
‎07-08-2002
04:07 PM
- last edited on
‎11-12-2025
01:40 PM
by
Content Cleaner
The first place to start is Chapters 18,19,20 of the LabVIEW Measurements Manual. This is a .pdf file that ships with LabVIEW. In the Development Library, there's a couple of links. Check out What is an Instrument Driver, Using IVI Drivers in LabVIEW , and LabVIEW IVI Class Sample Programs. The commands you mention are what are sent to the instrument to program it. The commands are unique to e
ach manufacturer and to each instrument. You need to look at the instrument's programming manual to learn the particulars of it's command set. It is much easier to start with an instrument driver because it hides a lot of the complexity and you won't have to do nearly as much debugging.
‎07-08-2002 11:37 PM
