GPIB inconsistent behavior
I looked at the code.  Do you need a non-default timeout change on the write command?  What happens after the error code, does it continually error or does it clear?
Message 21 of 27
(1,661 Views)
I don't think I need the non default timeout. If I continue after error it starts to continue to error on the  write GPIB vi inside the while loop.
Message 22 of 27
(1,657 Views)
I tried to add the 10s timeout into the GPIB write but it did not help.  The same error occurs. Smiley Sad
Message 23 of 27
(1,652 Views)
Would it be possible for you to post a NI-Spy capture here? It sounds like your GPIB is not ready to write. Seeing what lines are asserted could be useful to troubleshoot.
Message Edited by MXI Master on 06-17-2008 04:14 PM
-Marshall R
Message 24 of 27
(1,630 Views)
How do I do NI_Spy capture? Is there a manual? Thanks.
Message 25 of 27
(1,627 Views)
Start->Programs->National Instruments->NI Spy (to launch program)
Menu -> Spy -> Options -> Select 488.x API only
Click on Start Capture (green arrow)
Run your vi's
See what shows up.
Stop Capture (red button next to green arrow)
Save it, Post it.
Good Luck,
Message Edited by Drewski on 06-17-2008 04:31 PM
Message 26 of 27
(1,624 Views)
gives the same error number 6.
Message 27 of 27
(1,620 Views)
