GPIB USB HS installation
I'm having a little trouble installing my GPIB USB HS interface.
I've installed the 488.2 into Windows 10.
it recognizes the GPIB USB HS Max. if I right-click I don't get anything i.e. configure or enable?
Question, do I have the right driver installed etc.
thank you
(2,247 Views)
Hi chrlum,
What did you install?
Do you see the device in MAX? (Can you show a screenshot of MAX?)
Can you test the device in MAX?
Does MAX detect external devices connected to your GPIB interface?
(2,212 Views)
 The GPIB-HS requires three things...
  1. Base drivers. These should have been installed when the device was first discovered by Windows
  2. NI-488.2
  3. NI-VISA (the full VISA not just the VISA Run-time)
=== Engineer Ambiguously ===
(2,190 Views)
