GPIB / Serial driver substitution
Hi. I am trying to control my first legacy instrument using LabVIEW. it is a Tektronix TDS 320 (scope). I am talking to it via Serial (not GPIB). The only drivers I can find for it for LabVIEW are GPIB. Would it be possible to port these drivers from GPIB to Serial, or would I need to write my own drivers.
Cheers, Alec
(2,985 Views)
Accepted by topic author alecjcook
Hi Alec,
you should replace all GPIB-calls with VISA-functions.
Then it's rather easy to select the correct bus for communication, as VISA supports both of them (and some more)...
(2,979 Views)
@GerdW wrote:
Hi Alec,
I would say you can reuse about 95% of the driver code. But it is some important differences between how the communication is done regarding RS232 and GPIB. The "TKTDS 3xx Application Example.vi" will not work by only porting visa setup from from GPIB RS232. The diffrerence is explained in the programmer manual. Here is a source. http://webphysics.davidson.edu/faculty/dmb/py310/tds320.programmer.manual.pdf
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,970 Views)
