GPIB Problem in Labview
I am using an Agilent 82357A USB to GPIB controller.  I have set the NI VISA resource as the primary and the Agilent to Secondary.  I can view the Agilent VISA resource in the Max Explorer.  I have one device connected and under Miscallaneous VISA resources, it shows "GPIB0::INTFC" ,"GPIB0::16::INSTR" , "GPIB0::17::INSTR".  This all seems to be working.
However, in labview I am trying to use the labview GPIBWrite module/function to address "16".  I have tried using "16" and the three addresses listed above.  However, I cannot communicate to the analyser with this function.
any help is appreciated.
Bryan
(3,436 Views)
You can't use the GPIB functions. Those are only for NI boards. Use the VISA Read and Write functions.
(3,434 Views)
Thanks Dennis.  I was given a VI that uses the GBIBWrite function but i will either have to change it, get a Labview card, or not use it.
What a shame!
Bryan
(3,427 Views)
To change a driver that uses VISA instead of GPIB is usually pretty simple but tedious. Generally, it's just a matter of replacing each GPIB Read/Write with VISA Read/Write. You can leave the address string controls as is but I prefer to replace those with a VISA Resource Name.
(3,422 Views)
