GPIB PROBLEM
The Gateway Address should be the same as your PC's static IP address (192.168.1.2).
Message 61 of 66
(1,193 Views)
Uh-oh, now you've done it.  He can no longer reach the internet.  😉
Bill
CLD
(Mid-Level minion.)
Message 62 of 66
(1,177 Views)
@crossrulz wrote:
@nizam2 wrote:
Do you mind if i ask? How to connect my TD3012 to my laptop?
We are recommending an Ethernet cable
Is that a "Royal WE?"Heart
Yeah He has a point though.
routers are fairly cheap it your IT department premits them
"Should be" isn't "Is" -Jay
Message 63 of 66
(1,155 Views)
No, there were others in this thread that recommended the Ethernet cable.
And you don't even need a router.  A simple, really cheap network switch will do as well if you use static IP addresses.  I made a whole test system work that way and it was beautiful how everything played together.  And it was A LOT cheaper than GPIB.
Message 64 of 66
(1,145 Views)
A router would allow you access to the internet while still being able to communicate with your equipment in DHCP mode... IF your IT allows that.  I guess he never figured out how to get back onto the internet after he set his static IP address.
Bill
CLD
(Mid-Level minion.)
Message 65 of 66
(1,130 Views)
In my world, Test System = not connected to any outside network (including company network).  I will network a few test systems to keep a local repository, but they do not go beyond that.  I do this for performance (no need for the firewall, virus scan, etc.) and stability (I know exactly who has what IP and it never changes based on how a router feels that day).
Message 66 of 66
(1,107 Views)
