GOOP wizard
I have labview 5.1.1 pro I think. Whatever the big one is that work bought.
I don't see a GOOP Wizard on my projects menu. Did I do something wrong in
the install or something not to see this? Any hints?
-joey
(3,878 Views)
> -joey
If I remeber rightly there is no GOOP in the package.
It is either a seperate purchase or a 3rd party (can't remember).
At least this is what my leaky mind tells me.
Kevin Kent
(3,877 Views)
Try http://ni.com/goop
-Jim
"Joey Oravec" wrote:
>I have labview 5.1.1 pro I think. Whatever the big one is that work bought.>>I
don't see a GOOP Wizard on my projects menu. Did I do something wrong in>the
install or something not to see this? Any hints?>>-joey>>
(3,877 Views)
"Jim Kring" wrote in message
news:3a02683e@newsgroups.ni.com...
Ah beat me to the punch. I was going to reply to my posting. They didn't
make it entirely clear that goop.zip at that URL and goop.zip at the
zone.ni.com are completely different files. The latter is an example which
comes up on nearly every search, the former is what I wanted.
Still have a problem. Did the install with ProG 5.1.1. Didn't add itself to
my Project menu like it claimed it would.
Found the LLB and some other things so I'm going to screw around with it
directly, but still am not quite sure what I'm doing with it since it's not
working as-intended. Any hints on why it didn't add itself to the project
menu?
-joey
(3,877 Views)
Duhhhhh... fixed my own problem yet again. Guess I shouldn't be so quick to
post.
The default location for the installer was C:\Labview5.1 which I assumed was
right. Nope. C:\ProgramFiles\NationalInstrument\Labview
it is definately among the least friendly installers ever. Doesn't offer a
Browse dialog for that path. I had to go figure it out, then cut and paste
it in. Not that it's impossible to do w/o browse, just an extra
user-friendly feature.
...not to mention programfiles is the default install location for LV5.1
anyway. Not quite sure why GOOP would therefore default to C:\Labview5.1
Anyway. It now works. thanks
-joey
(3,877 Views)
Joey,
I am a big fan of the GOOP style of coding. If you want to check out an
example of a set of VIs I have made and found very useful on countless occasions
check out the following link:
http://www.calbay.com/timing/GOOPTimer.htm
-Jim
to>post.>>The default location for the installer was C:\Labview5.1 which
I assumed was>right. Nope. C:\ProgramFiles\NationalInstrument\Labview>>it
is definately among the least friendly installers ever. Doesn't offer a>Browse
dialog for that path. I had to go figure it out, then cut and paste>it in.
Not that it's impossible to do w/o browse, just an extra>user-friendly feature.>>...no
t
to mention programfiles is the default install location for LV5.1>anyway.
Not quite sure why GOOP would therefore default to C:\Labview5.1>>Anyway.
It now works. thanks>>-joey>>
(3,876 Views)
