GOOP object data is disabled
I'm building a class using the GOOP Wizard. After adding a few methods, suddenly some of the data is disabled (greyed out) in the list of accessible data.
Trying to recreate these in the Class data typedef does not help.
Is there a size limit for the data typedef? I do have a couple of Waveform type data in there...
I'd be thankful for any help.
Morten
(2,459 Views)
There actually is a limit for the number of controls that can exist in a paticular front panel or type def. Although it should be a fairly high limit. It is not something that we can put a number on however (ie. you can have up to N controls), as it depends on the complexity of the data types being used.
-Aaron Marks
(2,459 Views)
