GM10 yokogawa + Labview
Hi everyone,
I'm currently working on a project that involves using a Yokogawa GM10 data logger with LabVIEW. I'm looking for a VI  that can interface with the GM10. Does anyone have a working VI or any experience with this setup that they could share? Any help or guidance would be greatly appreciated!
Thanks in advance!
(212 Views)
GM10 Model supports both Ethernet and USB Communication.
But it has to set it before you start using below LabVIEW instrument drivers.
For USB, please refer Yokogawa website and install the usb driver, make sure it reflects (No warning) in Device Manager when you plugin.
For Ethernet, you need to use Hardware Configurator tool provided by Yokogawa to set the Ip address. Refer Yokogawa user manual - hardware configurator.
Refer below LabVIEW instrument drivers,
Yokogawa GX Series - Ethernet, Serial Driver for LabVIEW - National Instruments (ni.com)
Hope it helps.
(149 Views)
