Fundamental test question
How does this even work? (see atachment) How do you know what the feed back loop is initialized to? I built this VI and put probes on it. The output of the FB is always zero. This is what I can tell , the index is saying to start insert at the second element in the array. The I terminal is element to insert (0,1,2) for the 3 itterations.  The out put of the FB is the array to insert into.
What am I missing?
Alan
(3,634 Views)
Accepted by topic author ajmartin
The answer is going to be D.
The array is initialized to
[1 8 6 2]
This is done by passing the array to the blue dot on the left side of the for loop.
Iteration 0
[1 0 8 6 2]
Iteration 1
[1 1 0 8 6 2]
Iteration 2
[1 2 1 0 8 6 2]
So you are left with choice D
Message Edited by Cory K on 09-15-2009 11:18 AM
Cory K
(3,630 Views)
Well thanks for that. I have studied arrays and For loops, but was a little iffy on the feedback things, so I used LabVIEW detailed help. I knew the problem was in initializing the FB but I could not see any way to do it in this case. I mistakenly thought the blue dot was a tunnel. It went down hill from there. I see it now and now my example VI works
Thanks!
Alan
(3,596 Views)
please mark cory k as the solution
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,593 Views)
Sorry , Im new around here. I think I gave the Kudos correctly, How do I mark cory K as the solution?
Alan
(3,574 Views)
go to option at the top right coner where you have marked your solution and select unmark as solution and than mark cory's
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,572 Views)
