Function palette polymorphic vi missing icon
I have a problem that every polymorphic VI that I put on function palette is missing icon (question mark is displayed). All other VIs icons are displayed correctly. Of course, polymorphic VI exists on the specified path and its icon is the same as the icon of its sub-VIs.
I have LV2012.
(3,626 Views)
After LV2012 SP1 upgrade problem remains.
(3,574 Views)
how do you add those VI to your palette? do you use VIPM or do you simply Tools >> Advanced >> Edit Palette Set... ?
Epictetus
Antoine Chalons
(3,567 Views)
(3,565 Views)
I'm sure there is a solution to your problem, I'm sorry I don't know what it is, but maybe you should start using VIPM anyway, the free version can really make it easy to create packages that you can install on any computer.
Hope this helps
Epictetus
Antoine Chalons
(3,562 Views)
Dear andrej!
Since we have the VI Package Manager and the inside this the VI Package Builder tool, I recommend to use these to insert a new element (or submenu) into the function panel.
Here you can find a very detailed Hands-on about the topic: https://decibel.ni.com/content/docs/DOC-17536
BR,
CLA, CLED
(3,552 Views)
I've seen this behavior in the past too, and I've always used VIPM to create palletes (the other was is sooooo cumbersome).
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(3,551 Views)
