Function of the File Dialog.vi
The FileDialog vi functions nicely, but the button choice is only "Save" or "Cancel". I would like to use it in a file open process to choose the path. Can the Save button be changed to "Open"?
(2,592 Views)
William,
Here is the issue. LabVIEW is actually using the Windows File Dialog for this task, so this is actually a Windows thing.
If you are choosing only an existing path, then you can create a constant on the select mode (2) input to this function. If you choose existing path, then the button will say Open as you would expect. If you choose new or existing path, then the button will say Save originally because a user can type something and save the typed value as a new directory. If the user selects a directory, then the button changes to say Open.
Randy Hoskin
http://www.ni.com/ask
(2,592 Views)
