Function ncGetTimer.vi compatibility with XNET library
During one of my projects, I had to develop a CAN driver to communicate with a product to test. The CAN card then used on the bench's computer was a PCI CAN Series 2 card, which is now obsolete. The development of this driver was done using the NI-CAN API, and the correct functioning of this driver was validated.
Duplications of this same bench are now in progress and we are now using PCI NI-8511 cards (XNET). So I have taken the steps to migrate my CAN driver to XNET but an error occurs when using the ncGetTimer.vi function:
Error -1074388732 occurred at NI-CAN Get Timer
(ncGetTimer.vi)
Possible reason(s):
NI-CAN: (Hex 0xBFF62104) The property ID, attribute ID, or operation code that you provided is invalid. Solution: Read the function description and verify that you provide a valid ID.
So I wonder: is this function compatible with the XNET library?
I searched in NI-CAN and NI-XNET documentations but I did not find any information indicating that this function is compatible or not with the XNET library.
Did someone have this same issue when migrating a working CAN application to XNET library?
I use this function when there is no data read in a CAN Object, to get the current timestamp and to check if the CAN communication is still responding.
Thanks in advance,
(1,465 Views)
Please confirm whether you have tried following Migrating NI-CAN Applications to NI-XNET guide.
(1,336 Views)
